Pad Kits
  • Thread starter Thread starter D
  • Start date Start date
D
Are we ever going to see a pad kit similar to the Pinnicle XMT Swirl remover ones, except with Edge 2000 pads instead?
Thing is... prices would have to be a little higher. The pads are more expensive AND add in the adapter. Also people would be stuck with an extra adapter if they have Edge pads already. I still hope they do this, because Edge pads are awesome!
:iagree: and people need to look at edge pads, it's like buying two pads in one.
Push pull flip! Wow new pad!
That's the number one reason why I went with Edge is the dual sidedness. Second would be the simple adapter.
The adapter is better then the velcro because eventually the velcro would always start coming off of the pad for me.
What caused that? Amount of useage? Cleaning?
I think its a combination of washing it in pretty hot water and just regular usage.
Another thought is to give an option to go with the smooth or the wave pads in the new kits. Even another thought is to go with a custom kit were we can say how we would like our pads built. One half/ side one material, the flip half/side another material. Edge says that they can do that in the Edge video.
You're right Jimmie, the custom pads would be awesome.
Anyone else interested in this???
At the least I'd really like to see someone do a review of a different sided Edge 2K pad. I can see having let's say a white/green and going back to the green side to just spot an area and then right back to white. Or one side wool; wax on with foam; wax off by flipping and throwing a bonnet on the wool. An idea would be to ask all on the forum if they had the option of a two different sided pad what would they chose to put on each side. Anyway I'm with you.
