Rastaral39
- Oct 5, 2011
- 82
Hello everyone, first question from me. been doing some detailing for about a year now with some great results on some nicer cars thanks to a lot of reading on this forum. My question is about pad priming. Maybe there is not one hard and fast rule. At first I started with the quick mist of the pad with pad primer then 4 dot method of product then went to it with good results. Then i started pad priming with product with good results. The other day i tried using a Green lake country polish/compound pad and tried the priming method of semi saturating with product [m105] and then going to it-well my Flex DA slung product everywhere. I have seen some video's where the method used was a light mist with pad prep and then a small amount of product, polish and work as normal. my question is which method is better and is it really necessary to prime pads with product? Seems like in the older videos pad priming with product was not done much. Maybe newer pad/product combo's have changed the need to do this.
