maxniman
- May 30, 2011
- 93
This weekend I was polishing/sealing my new Grand Sport. I was applying Menz 4500 with a gray 6" kompressor pad with a 5" megs backing plate, setting of 5 on my PC. The pad kept moving off center and finally just came off. I finished with a kompressor red pad but it to starting shifting off center and each time I stopped to apply more 4500 I would have to recenter the pad. these pads are ~ 1 year old. My question, after multiple uses does the backing on these pads wear out or is the problem with the backing plate? following the 4500 I applied Wolfgang DGS with a kompressor gold pad and had few problems - which would seem to indicate that the backing of these pads was too worn to stay attached to the backing plate. I am a hobby detailer on my DD so these pad see little use. Any thoughts?Feed back please
