Remember the Flex has '4' (at least) backing plates,
the original 5.5",
Flex XC 3401 VRG 5.5 inch Backing Plate
the original 4 3/8" smaller plate
FLEX XC3401 Mini 4 3/8 Backing Plate, FLEX
and the Lake Country Changeable Backing Plate system, which includes both a 4" and ~6" plates.
FLEX XC3401 Changeable Backing Plate System
The Hybrid pads will fit:
- 6.5" Hybrids on the OEM 5.5"
- 5" Hybrids on the LC Changeable 4"
My favorite setup is the 4" plate and 5" hybrids, all day long.
My wish is for LC to make an Hybrid suitable for 4 3/8" plate, I 'feel' it's the sweet spot for polishing an entire car without being too bulky for small parts neither too small for larger panels. Again, just my thoughts.
Hope that helps,
Kind Regards.
As Rafael stated, the larger 6.5" Hybrids fit perfectly on the standard 5.5" Flex plate. The smaller 5" Hybrids need the 4" plate that is included in the LC Changeable Plate System.
For a one size fits all approach the 5" pads are going to be your best bet. This will allow you to get into smaller areas than the larger 6.5" pad. The smaller pads are also ideal when working on cars with varying panel designs. If you do a lot of larger SUV's and trucks, then the 6.5" pad will be the choice as you can cover the larger flat panels easier.
Yinzer. That's funny. I did a double take. Did you hear the guy from Mike and molly on dve a couple days ago. His yinzer rant was funny as hell
Sent from my SPH-L710 using AG Online
