Pad Washer + Pad Priming
FPEvo
So I've already read Mikes DA pad priming and use the circle method myself. That being said, im about to pull the trigger on a pad washer.
After washing the pad in the pad washer, should i reprime the pad using the circle method, or just use "working product"?
Should reprime the pad....
As it will be in unused condition after washing.
If you are going to continue to use the same product and pad, this is where cleaning your pad on the fly can work as well.
I was under the impression that the pad needs to be completely dry before re-use or am I mis informed??
I believe it can be somewhat damp, but you want to get it dry as possible. Some people use water to prime their pads, so goes to reason as long as the pad isnt soaking wet or flinging water, it should be okay to use.
I keep a bucket with APC and water, toss them in there while I move to new pad. after teh 2nd pad, ill hand squeeze /clean them, put on DA and set 6 , spin, roll up in a towel and squeez again and set them out to air dry while I use my 3rd pad. damp is fine.
I use the on the fly method most of the time, but I was just going to use the pad washer between panels instead
