I'm going to toss out my thoughts on pad washers here. No idea if anyone else agrees, but I run my business on the side and do 1-2 cars a week cleaning about 12-20 pads a week. I don't clean my pads as I work, I prefer to just have a ton of them to use and I clean at the end.
I've tried all kinds of cleaning products and the bucket grit guard pad washers. In the end I have found it faster and more enjoyable and more thorough to just clean them by hand.
I have the dp pad cleaner in the jar and I mix that up in a bucket and soak the pads for 10-15 min and then bring them to the wash tub to clean under warm-hot water. I've experienced maybe one pad fail by separating from the hook and loop material with this method but keeping in mind the pad was about 2 years old and had been used on countless cars.
My best advice is to clean your pads as soon as you are done with the vehicle. I've found that a good amount of my pads can come clean with warm water only if you get to them before your products dry up in them.
So my recommendation is get the dp pad cleaner concentrate, mix it up in your bucket and soak pads for a little bit. Head to the sink and clean and rinse and I also keep on hand a bottle of Wolfgang pad cleaner for any more stubborn pads. Save yourself some money on a pad cleaner and try this method out.
This is all my opinion from trial and error and people may not agree, just wanted to give you an opinion from someone who has tried many options.
Does anyone else not just toss them in the cloths washer with towels?
I wash separate you don't want that lingering product to get on window towels.
what pad cleaner and brush do you use to clean them?
