Not sure exactly how the Vette system works but the principal is the same.The paddles are just a way of shifting gears without taking your hands off the wheel OR moving your shifter to far in one direction or the other.Once your are in drive there will be a spot to move the shifter to sequential mode. From that point on the paddles control which gear you are in.Upshift is usually one click on the right paddle, downshift is one click on the left. TRAIN YOUR HANDS, the wrong click can be bad but very very fast.The paddles come out of racing cars, make the shifts very fast and sequential (you cannot shift from first to third, or worse from fourth to first. They go one gear up or down at a time, sequentially, in very fast shifts. Fortunately, or not, the automakers have built in a sense of self-preservation into most cars with this and they will not shift if the revs do not match. Six thousand RPM in fourth will not downshift into third causing bad things to happen when the engine goes to nine thousand RPM, briefly. Learn where the match points are, up and down, and you will have a very fun car to drive indeed. See your dealer or manual for details and there is probably a gear indicator on your dash so you know which gears your in. Start in first.JSR
