Hello everyone,
I've had a rust spot on my Lexus IS250 since forever and I recently decided to finally do something about it !
After gathering many information from videos and threads on different websites for weeks, I felt I was ready to begin with the repair.
I already had many different products in my possession (polish, compound, clay bar, putty, primer, spray paint, clearcoat, ...) as I knew some day I would have enough time to try and enjoy detailing my car.
Before the "big task", I successfully managed to erase a few clearcoat scratches which boosted up my self-confidence and gave me strenght to go on with the rust repair. Yes, I was a bit afraid with the idea of sanding my car body to bare metal ! Anyway, this isn't the topic here.
I roughly followed this procedure :
In an effort to blend the new paint with the old, I used a technique found on many websites : stick folded sheets of paper on the body panel when spraying so that there is a smooth transition between the old and new paint.
The result isn't so bad in my opinion, but the big problem is that the new paint doesn't blend at all with the old one. I didn't think it would be so visible, as you can see on the below pictures.
View attachment 69996View attachment 69998
For better understanding for you, I added color on the picture on the right : the red line is where the rust was located, the green area shows more or less the "primer area" and the blue area the "paint and clearcoat area". Of course I unhooked the rear bumper as it wasn't contaminated with rust.
So I got three questions for you :
Thank you for reading so far and excuse me for my eventual mistakes. English if not my mother tongue and I'm not a detailing professional as you can see ! :laughing:
I really look forward to reading your advices, answers and opinions about this ! :xyxthumbs:
Needer
- Sanding the rust spot to bare metal and verify that the rust didn't contaminate the undercarriage or went through the body panel.
- Apply putty mixed with hardener (I chose polyester putty).
- Sand it to get a smooth result.
- Apply finishing putty to fill the smaller holes.
- Apply three coats of primer (I chose white spray primer) on a larger surface than the rust spot (to blend the paint).
- Apply three coats of spray paint on a little larger surface than the primer (again, to blend the paint).
- Apply three coats of clearcoat on the same surface as the spray paint.
- Wetsand the whole area and even a bit further into the old paint.
- I would like to improve the result and I thought (I really don't want to redo the whole process) I would reapply one or two layers of spray paint a bit further than the blue area and then some clearcoat to try to smoothen the rough transition. What do you think about that ? Please keep in mind that I want to avoid having to sand everything back to bare metal and start again.
- What I find disturbing is that the new paint seems to blend perfectly with the bumper, any explanation why ? Is it some sort of optical illusion caused by the gap between the bumper and the body panel ?
- Finally, if you look carefully on the picture, you can see that there is a "spiky part" in the painted area (on the curved edge) which blends perfectly with the old paint and I really don't understand why. Any hint ? Did I wetsand too hard and removed my new paint on this edge ?
Needer
