Mineral Spirits does a nice job cleaning up the finish after compounding and polishing. It's a petroleum based product therefore additional cleaning steps might be needed but this depends on what those next steps are.
Optimum Opti-Coat requires an IPA solution cleaning step prior to it's application...
- Polish paint to remove any defects.
- Clean surface with 15% IPA solution to remove all polishing oils, waxes, and silicone's.
- Prime the applicator by making an X pattern across the pad. Only a few drops will be needed for each subsequent panel.
- Wipe Opti-Coat onto a single panel at a time in a thin layer using two directions, front to back, and then side to side.
- Within 5 minutes, inspect the panel with adequate lighting looking for any thick areas that have not flashed away to clear.
- Use foam applicator or paint safe microfiber to even out any areas where you see streaks. This step is key, as any spots not leveled will have to be polished if allowed to cure. Panels will feel a bit tacky and will be self-leveling during cure time, so avoid any unnecessary touching, wiping, or contact to produce the best results.
- Repeat steps 1-6 for each panel where application is desired. Not recommended for glass.
Application Video
[video=youtube_share;Yyo_-UA8yM4"]Opti-Coat Application Methods - YouTube[/video]
