Paint is no longer smooth
AutoApollo
Hi all, I've just finished detailing my ford focus that has had no previous detailing done. I started off with a two bucket wash followed by a clay bar. Next I used meguiars ultimate compound with an orange pad and ultimate polish with a white pad. All performed with a griots garage 6in orbital buffer. Lastly I used their gold class paste wax with a black pad. The car now looks fantastic and feels buttery smooth. But after just two washes and two weeks later, the car's paint no longer feels buttery smooth. Is there something I'm doing wrong? Thanks
Tell us about how you are washing, what is your soap/dilution, what wash media? Water quality? How is the car parked, outside, inside, under trees, do you live near railroad tracks or park at work near any industrial facilities?
Hi, I use meguiars gold class soap diluted in a 5 gal bucket. I use a expensive wool mitt and apply light pressure when washing. Between each panel I rub the mitt across the grit guard in the bucket to rid of any dirt. The car is always in the shade and I make sure the paint is nice and cool. I live in a residential area with railroad tracks up on a hill about 500m away.
What soap dilution are you using? Is the car parked outside overnight?
I guess I just presumed that you were saying that the paint now felt "rough", but re-reading what you said--are you saying that the paint no longer feels "slick"? It's still smooth (as in not rough), but doesn't have that "just waxed" feel?
As an old forum friend Mosca used to say, "the best way to get that just waxed look is to have just waxed".
Is the car parked outside all the time?
It's possible there's some type of airborne contaminants landing on the paint on a regular basis. For example, tree sap mist. On a hot day green plants/trees can emit fine droplets of tree sap that can become airborne and land on your car's paint.
Worse if you park under a tree on a hot day. Then there's industrial fallout. Traffic pollution if you live in an area that's densely populated with a lot of car traffic like Los Angeles. And then there's always airborne overspray paint. Like a housing project where a tract of houses are being painted by spray gun.
Have you ever done the baggie test?
The Baggie Test - How to inspect for above surface bonded contaminants
Sorry Mike, I guess that was before my time, I just remember Mosca using that as his signature over on MOL--you ever hear from him?
The car is still smooth but not buttery smooth. Almost like small contaminants stuck in the paint. It is parked outside and during the day can get beat on by the sun. I just don't want my hark work to go to waste (the paint correction and all). How often should I wax? Is there a good sealant from meguiars anyone recommends?
The slickness of a fresh coat of wax will wear off. The slickness of a sealant will wear off too, not usualy as fast.
The slickness of some paint coatings probably lasts the longest.
Take a look at the DP Paint Coating, it's easy to use and leaves the paint feeling very slick. Not all paint coatings do this.
Another option is to learn how to use a waterless wash and a spray wax. Waterless wash to remove dirt and dust.
A spray wax is to boost wax protection, gloss and shine and the one I link to below really does a great job of imparting a slick feel to the paint. The key point being you need to use something to clean off any dirt before using a spray wax. You don't use a spray wax to remove dirt. Make sense?
Personal favorite
Review - NEW BLACKFIRE Midnight Sun Carnauba Spray Wax!
Besides that you're dealing with a daily driver.
Personal favorite
The thing is. I have been using the "quik spray wax" from meguiars and I can do maybe 5 waxes with it. It just seems expensive!!
BINGO! You are probably getting fallout from the railroad tracks on the paint. There is absolutely nothing you can do to prevent that other than covering your car. The rust particles as well as other environmental fallout is a part of life. I work under an airport approach and after a few weeks my cars paint feels like sandpaper as well.
You might want to look at added Ironx to your use as that will help dissolve the iron particles being deposited to your paint.
As far as using an entire bottle of Megs Spray wax in 5 applications, you are using way to much. It should last a lot longer. With that said, consider trying some other spray waxes like the new Blackfire or XMT Spray wax. XMT is a great value.
Damn train tracks! Thanks for the info :)
I agree.... the steel wheels riding against the steel train tracks creates metal particles that become air borne.
Also, next time you hear a train go by listen for the
Clack Clack
Thats when the wheels hit the space between two sets of tracks and there's more wear from this contact.
Iron X is your friend.
Iron X - Bleeding like a stuck pig
watermark.php
Which one are you using? Ultimate Quik Wax or the one in the burgundy bottle?
YOu should consider getting D156 from the detailer line. It is the bulk version of UQW. But it does sound like you are using too much product. A little goes a long way.
UWQ/D156 is pretty durable. Using it as a drying aid every wash or every other wash may be something you might want to do.
Okay I will use less!! It's just obviously not as buttery feeling as as my paste wax so I feel like I need to put more on. I mist on and wipe off.
