Hi dear
Is this down article is right
Most vehicle paint film systems (127 - 178 µ) which comprise a Primer coat of 2Mils (50 µ) and a Colour coat of 1-2Mils (25 -50 µ) and Clear coat 2-3Mils (50 - 75 µ) a surface scratch that will `catch' your fingernail is approximately 0.04 Mil (1.0 µ) deep will usually require wet sanding and refinishing.# Generally speaking the clear coat makes up 50% of the total paint thickness. The paint system is split 50-25-25% please note that this is a very general approximation# Measure the inside of door; this will give you an approximation of the paint system minus the clear coat. The difference between readings inside the door and on the exterior paintwork gives the thickness of the clear coat )it should be noted that some vehicles do have a clear coat) Removing more that 0.5 mil (12µ) of clear coat will cause premature paint film failure as the ultra violet (UV) protection percolates to the top of the clear coat, there is ultra violet (UV) protection all the way through the paint, but the majority of it migrates to the top of the clear coat along with the thinner solvents and particles.# These numbers are offered as a guide only, as there are too many variables to provide any more than an approximation. Note: 1 µ (micron) is 1/1000th of a millimetre or 0.0393700787 Mil or 0.001 of an inch • 200µ + can be expected on older cars that have been hand painted or a re-painted vehicle • 100 – 200µ 4 – 8 mil - normal paint thickness# • 80 – 100 µ - 3 – 4 mils, thin paint# • 80 µ < - less than 3 mil, very thin paint
Sent from my GT-I9100 using AG Online
