Paint on tires.
Ted S.
Intro.
A good friend of mine recently bought a set of Aluminum blade rims; which he purchased for a very good deal: about $250 with tires. The reasone the previous owner sold the rims was because he had clear-coated the tires, and probably not prepped enough. I guess they looked really bad.
Ok, so my friend used something called Aircraft to remove the paint. But there is still a good bit of paint left on the tires.
Question
Is there a safe method to remove paint from the tires?
¤Note: I used some ARO and removed some of the clear, but it seemed very ineffective to remove the paint overall.
No, there is nothing that will easily remove paint off a tire. Tell your friend they better get use to it, or get another set
Which I had better news
Flash
U
Is the clear on tyre sidewalls??? :confused:
A bodyshop had gotten some clear on my window trim(rubber) and I removed it with a terry towel and IPA.
On sidewalls, you can use ARO or OPC with a tire scrub or brush(Cobra Flex Foam Tire Detailing Bundle Buy One, Get One Free!)
I'd be pretty aggressive on the sidewalls.
I used some ARO and one of the scrub applicators when I detailed his car last, but he was in a hurry and said not to worry too much at the time. I'm going over there tomorrow, and may try this some more. Maybe a good bresh for the lettering.
U might wanna mask the rims if you're going aggressive on the sidewalls.
I was wondering how wheel brightner or some oxalic acid based rim cleaner would respond to it! (But I always keep all that hazardous stuff for worst case scenarios! :eek:)
Have you tried lacquer thinner? with a brush.
