Paint safe cleaner/degreaser?
Supergus1
175
Soo,
It looks as though Mother Nature isn't quite finished with us here in the Northeast:mad:. I've been utilizing the touch free auto wash and coin-op wash bays all winter long but about once a week or so to try minimizing the build up of road crud. Recently though I've noticed that little by little the residual grime is getting thicker and harder for the wash jets to remove. What can I use as a cleaner or presoak to cut through and loosen up the grime that won't strip the wax? Thanks in advance.
Yes I feel your pain but unfortunately degreasers/paint cleaners will strip your wax when the weather gets a little warm just wash the heavily dirty areas with a dregreaser, and just replace your lsp even if it's spray wax
I dont know if you would want to try, but wd40 is known to be a safe degreaser for tar and road grime
Soo,
The build up is getting worse because your losing your protection. Next fall try Collinite 845 or better yet, use Opti Coat 2.0.
Ahh, makes sense! I last waxed it back in Oct. and was hoping to get one more detail in before winter but it didn't happen. Thanks for the reply.
wd40 had an ad that it removes road tar on paint, dont know if it still applies
It will do this. But think a bit more about the product. It is designed to be a water resistant lubricant. To lubricate, it deposits something oily such that two surfaces in contact can slide over each other with minimal snagging. To be waterproof, this lubricant cannot be easily removed with a bit of water over it. As such, spraying it onto your paint means that you will deposit this water resistant lubricating oil (only a small component of the total WD40 formulation).
