Frenchie
- Mar 9, 2012
- 98
Ok well I have landed a pretty large job for myself and have a question about paint thickness. It is a custom vehicle that was completely resprayed after completion(2007). It was painted in a factory blue(Viper GTS Blue), but there is no telling if it was painted using factory paint or a custom blend. This is a 100k+ vehicle with quite a bit of history and I absolutely want to be sure of a few things before I get to work Friday morning.
The question is....
Considering there is no way of knowing what paint, and how thick it was laid. Anything I need to take into considering?
I plan on masking off all of the top edges and corners, then going back and buffing those by hand. Only polishing out the flat panels. Lucky for me, there are very few edges to worry about. I will more than likely start with some 105 and a wool pad on a rotary...JK!!! Ok I will probably test out the worst area starting with a LC Gray pad and 205. It was detailed last year, but has been outside since then. There are some scratches and other blemishes, but the main thing is the new owner knows this and accepts them. However the shop doing some work on it wants it to look it's absolute best before getting put in a container and shipped across the ocean.
Discuss...
FWIW I know I did not include much information about the vehicle and that is intentional to protect the current and future owner. If you have any valid advice and need more specifics we can discuss details over PM's
The question is....
Discuss...
