Just wondering if clear coat paint jobs are generally thicker since they have a 3rd coat of paint? Or are the base and primer coats of a single stage job thicker than the base and primer coats of today's clear coats?
No easy answer.
When you measure paint thickness you measure total film-build, not just the part you're working on so it's hard to tell how thick the layer is you can work on .
Single stage pants tend to be softer than clear coat paints except for white paint and for this reason you want to always practice,
"Use the least aggressive product to get the job done"
You want to practice tis anyways for all paint types. Also keep in mind if you're working on an antique car with original single stage paints, you have no idea how many people have worked on the paint before you let along what they may have used so be extra careful on antique cars with single stage paints.
