Hi! I recently purchased a 2007 Acura RDX that is perfect in every way... Except for a hand-painted pinstripe that I want to remove.
I have already tried soaking the stripe with denatured alcohol and wiping it off with a cloth which didn’t work very well. This method also requires a lot of rubbing which I fear will damage the clear coat.
After doing some research it appears that lacquer thinner is the most effective solvent for this type of work. 90% of people say it works well and is safe on paint if used properly, while the other 10% says it will ruin the clear coat or will cause long-term damage that won’t be noticeable at first. Who is correct? If anyone has removed painted pinstripes with lacquer thinner before, what was your process?
