PC 7335 and pad recommendations
bcgreen
Member
I have owned my PC 7335 for 20 years now. Most of my old pads are Meguiars and it time to refresh them. I have Meguiar's products, Griots Correction creme and HD Cut and Speed in my arsenal. This one of my hobbies so it is not a business, but do an occasional customer who are absolutely thrilled with the results. It does take me much longer that most individuals because my equipment is verging on antique. I have read about LC HDO, LC Force Pads, LC Thin Pro and Microfiber Cutting pads, waffle weave, pads with holes or dimples in the foam and I am not sure what to get or to buy some of each. I currently use 4 & 6" pads.
I have noticed that the backing material on the Meguiars pads wear out to the point I have to apply adhesive.
I do own a Hitach. rotary which I use quite often because the PC just takes too long. I also don't own air supply.
In 2015 Mike recommended: Porter Cable 7424XP
Correction = Orange LC Flat Pad
Polishing = White or Black LC Flat Pad
Sealing = Blue LC Flat Pad
Correction step = 6 pads
1 for the hood
1 for the roof and trunk lid
2 for driver's side
2 for passenger side
Polishing step = 4 pads (You could probably get away with 3 if you use 1 for hood, roof and trunk lid)
1 for the hood
1 for driver's side
1 for passenger side
The LC Thin Pro pads are perfect on my 7336. If you use your Hitachi rotary for correction the LC Hybrid Force pads are my favorite.
Consider the updated Meguiar's pads.
The foams are consistent from d/a specified, and rotary specified pads, however the shapes are optimized to compliment the tool they're designed to go with.
