pc 7424 counterbalance
BILL
My new pc 7424 came with a 5" backing plate and a counterbalance thats says [use a 6" inch pad only]....I HAVE 6.5 AND 5.5 PADS
Then in the A/G counterbalance info page it says quote:
The counterweight is for use with a 6” backing plate only.
I have a 5" inch backing plate
very contradictory/confusing:o
5" BP for 6".0" thru 6".5" pads anything above 7" pads you'll need to go to a larger BP (6") and larger counter weight..
THANKS JOE........;)
I see you said your counter weight is a 6", have you changed it?
PC 7424 has a 5" CW
PC 7336 comes with a 6" CW :confused:
it just says on the [balance] use with a 6" pad.[not saying that its a 6 balance]..so it must be a 5 balance.meant for A 6 -6.5 PAD
then the A/G page that sells the weight says:
a 5" came with my unit..... this post probalary means squat, but I'm curious anyway...
Thanks joe.........
