PC 7424 vs 7424XP !!!
Webb
I have the older model 7424 non XP,mine is working perfectly,my question is what's the difference between them ?
This is the older one with the speed dial in the back.
Thanks
More power, slightly different body design. Some members here have an older non XP model.
Non XP specs
Product Features
6-inch variable-speed random orbit polisher promotes swirl-free polishing
Powerful 4 Amp motor runs at 2,500-6,000 OPM
Random polishing action gives the surface an even, finished look
Measures 11-1/2-inches long and weighs 5-3/4-pounds
Includes polishing pad, wrench, side handle, and operating manual
XP Specs
Product Features
Random-orbit, swirl-free sanding/polishing action
Electronic variable-speed dial from 2,500-6,800 OPM
Includes 6-inch proprietary counter balance for use with 6-inch sanding/polishing pad
Accepts 5/16-inch to 24-inch spindle thread accessories
Features a 2-position (left or right) removable side handle for greater comfort and control
Got it from Amazon.
PS.Yeah just a minor difference besides the different body.
I believe the XP also has a longer cord but biggest difference is the XP has a more powerful motor with regards to torque output.
I have a 7424 that works great. Been thinking of upgrading to an xp but not sure if its worth it although i think they are reasonably priced. Maybe if I go to a rupes.
I love the PC not much difference between the two models. If getting another DA on a budget get the GG. If looking for more power then the Rupes, if still more power and you don't have a rotary then get a rotary. On a budget get the Dewalt if not the Flex 14-2. If you want a hybred rotary/DA but technically still a DA because of the action then the Flex 3401. Basically unlimited power, yet safer than a rotary for those; "I lost concentration dumb moments you wish you could of had a do over moments". Come on now everbody who has used a rotary knows what I'm talking about :buffing:
I also have an original 7424 - anyone know where to get replacement pads for them?
Don't bother with the stock pad That thing is worthless. Get a 5.5" backing plate and pads through Autogeek.
I've had by 7424 since 1999 and it's still going strong.
If I were you I wouldn't upgrade to the XP being you wouldn't see a big difference IMO
I upgraded from the XP to the Griot's DA and man what a difference it makes when performing a full paint correction.
You'd be hard pressed in trying to bog the motor down with the Griot's.
You could use your PC with four inch pads.
My PC is setup with the 4 inch pads and love the fact I have one with four inch pads and one with 5.5 inch pads. :dblthumb2:
