PC mf bonnets
Rsurfer
Hi,
Just got a pc edge kit. The mf bonnets doesn't seem to stay on at 5-6 speeds. Any suggestions would be helpful.
Rsurfer
the bonnets will spin off if you do not apply pressure, or maybe the pad is not centered properly, but I have never had a bonnet fly off while in use.
Yea u need to have preasure on it, If you have to move it off the paint you can always put your hand on it
mf bonnets are used for wax and polish removal ... as such you dont really need that speed anyways. Speed is for polishing with a polishing pad !
Thanks for the replies. I think I may have been lifting the pc while in motion. This what is causing the bonnet to spin off. I'll try to turn it off when lifting off the surface.
Rsurfer
