I've got the Meguairs G100 version of the 3.7amp PC 7335. It has a counterweight labeled for 5" pads only. Does this refer to the diameter of the backing plate or the foam pad itself? If it refers to the pad, can I install the 6" counterweight so I can use the 6.5" pads?
What is the effect of changing the counterweight? Does the pad just make larger orbits? Does it provide more aggressive action to the pad?
