Working to correct 2-year old silver Toyota. Swirls next to undetectable in daylight, like neon at night under overhead lights.
Approach was to remove as little paint as possible. Using Megs ult. P. (I'm still a newbie w limited supply of pads/prods.) Started with WHITE Lake CCS. After several passes, checked w lights and wasn't achieving desired result. Moved to ORANGE Lake CCS cut pad. Required a few passes and some downward pressure, but it worked...
Only own one orange, so out of curiosity tried a ChemBros hex GREEN on next section. This worked in fewer passes with less downward pressure!
WHY? Can't find logic in it. Maybe I'm not considering something fundamental. Any thoughts?
