I have been buying inexpensive car shampoo.
Are most cheap car shampoos NOT phnuetral and not good to use ?
thanks
Purchased a gallon of hyper. Will report back. Thanks
Hyperwash is super concentrated and thick. You only need 1 OUNCE in 4 gallons. That will be plenty for great lubrication. Mix it well in the bucket. I like to use a paint mixer on a drill. Its a great soap and I use it often.
Adding anything more than an ounce is a waste and you'll be leaving a lot of soap residue on the paint which will be harder to rinse away. I say this because there are a lot of folks that use the "glug-glug" method or just carelessly throw a crap load of soap in the bucket which is unnecessary.
thanks
I use CarPro Reset. It's pricey but worth it. Look into the IK12 Sprayer/foam canon. I don't use a foam gun but rather the IK as I can control the pH far more accurately.
I have 2 of those IK12s. Do you use the Reset as a pre-treat or do you foam as part of the regular wash (or both)? Thanks.
