Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Pictures & Comments from October 4th, 2009 Sunday Detailing 102 - Advanced Class
Everything is set-up and ready to go! Coffee will be hot! Donuts will be fresh!
October 4th, 2009 Detailing 102 - Advanced Class
The emphasis here will be to build on what you learn in our Detailing 101 class by learning how to wet-sand by hand and machine and then how to successfully remove your sanding marks using a rotary buffer and then polish the paint to perfection using a dual action polisher.
Nikken Finishing Papers - Backing Pads and Fresh Water Supply for Hand Sanding
Air powered DA Sanders - 3M Trizact Sanding Discs & Mirka Abralon Sanding Discs
Compounds, Wool Cutting Pads, Rotary Buffers
The PosiTest Paint Thickness Gauge
These classes are always so much fun not only do you get to learn a lot of tips and techniques for polishing paint but you always get to meet great new people.
If you couldn't make it to either of these classes, be sure to clear your schedule for 2010
See everyone on Sunday morning starting at 8:00am!
:dblthumb2:
:dblthumb2:
