I'm new to coatings, this is the first one I've tried.
For a perspective, I did this to a 2 year old vehicle with a well maintained finish, and virtually no swirls marks.
Basic Process:
Chemical Guys Wash and Gloss @ 1 oz / gallon (or more) for wash to strip previous sealant/wax.
Nanoskin fine grade mitt using nanoskin glide lube at 10/1(not a fan of their glide lube, but the mitt is a great alternative to clay).
M205 on hood, before realizing it was unnecessary.
PBL surface Cleansing Polish, applied with a black LC flat pad, Flex PE-14.
PBL Diamond Paint Coating, using Lake Country coating applicator & car pro suede microfiber applicator.
Pros: PBL coating is super easy to use, even for a rookie. Looks great. Super slick, similar to WGDGPS.
Cons: PBL cleansing polish is a pain in the butt using a rotary, dries really fast, reducing speed to 2.5 helps. Easy to work with by hand however, which leads me to believe its probably better suited to a DA at moderate speeds. I stuck with the rotary, rather than grabbing the DA.
Basic Process:
