NissanOwner
- Mar 4, 2006
- 181
Can I use this with a foam gun? or should I stick with DP.
Thanks for the help.
Yes, you may use it with a foam gun. However DP Xtreme Foam formula will foam up even better then Pinnacle. Considering Pinnacle's price, I'd stick with DP for the foam gun, and just use Pinnacle in a bucket.Can I use this with a foam gun? or should I stick with DP.
You can use pretty much any shampoo with the foam gun. I found that each soap will foam differently. DP Xtreme was formulated for the foam gun if I'm not mistaken. I've tried many soaps but I always come back to DP Xtreme in the foam gun. You can't beat it.
