•I’m not Mike, but IMO:Mike,
correct me if I’m wrong, but if all polishing steps will be done by the OP prior (if the OP decides to go the below route and finishes down to near perfection during his normal polishing), would application of jeweling wax with a gold jeweling pad or CarPro gloss pad provide some extra dazzling shine/gloss to the final look?
Obviously this would provide no correction, but perhaps does something special (smoothness/gloss) to the final look of the paint? I’ve always wondered “when is the right time to use these jeweling pads?” It would seem that the OP has the car and desire for max shine to warrant this extra step?
Please advise, for my own knowledge, and more importantly to give the OP an extra option if it is a sensible one. Thank you!!!
It's a 1957 Chevy Belair. "Matador Red" (orangeish red) It is 2 stage paint.
I will have the swirls removed.
It just want to take the finish as far as possible in the shine department.
I have an orange Griots polish pad.
I have a yellow Griots Boss polishing pad.
I have a white Lake Country polishing pad.
At least 6 pads per type to "work clean".
I did a test spot and found the paint to be hard.
Mike and all the other posters.......I appreciate your responses.
Yea I'm a weekend warrior. Love to keep my vehicles as nice as possible. I detailed cars when I got out of college in the early 80's. Nobody wanted to hire a fresh graduate during the recession so I made ends meat detailing cars. Used a rotary and wool pads. Boy has detailing come a long way since then!
I have been using a DA polisher for the last 10 years. The results were adequate but I really didn't pay attention to the details and the technique till I join the forum and started learning from the experts. I can officially say I have a detailing sickness. In addition to the original Porter Cable DA which I have converted into my 3 inch polisher......I have acquired a Griots 15mm BOSS polisher and a Flex XFE7-15 "The Finisher". Not to mention all of the products bought from Auto Geek....Griots....Sonax etc etc.
Mike....to answer your inquiry, I will do all of the correction on the car. I am a DIY so I can put hours into making the paint it's best. The Belair is a new car for me so I am evaluating the paint and want to develop a process for it right from the beginning. All my other vehicles are daily drivers so the attention to "Show Car" shine is not a priority.
On the subject of the test spot.....I started with the least aggressive method and then evaluated the result. The combination used did not completely correct the paint so I increased the pad and product cut and conducted another test IN A DIFFERENT SPOT (wink). Better results but still not 100% corrected. Is this indicating "hard paint"? That's what I am thinking.
Mike.....I missed your class last year at The Indianapolis Motor Speedway. Hopefully you are coming back at some point in the future so I can take the class.
Craig
-Since the Pinnacle Jeweling Wax is an AIO,
it contains a certain amount/type of abrasives
that’ll need a Polishing/AIO pad to fully put
these abrasives “through the mill”, so to say.
-That’s something that a Gold/Gloss-ing Jeweling
pad (and their much smoother/softer surface areas)
may have a difficult time accomplishing.
[Not saying it can’t be done, but: time is money;
(over)heat-ing is an enemy; and CCs are thin.]
