Pinnacle Liquid Crystal Waterless Wash Concentrate with Carnauba
fightnews
hi so i was wondering is the concentrate when diluted the exact same as the stuff you can buy pre mixed in a pinnacle bottle or is there a difference at all? i was going to buy the premixed stuff for twenty but the concentrate is a much better deal with the towels and stuff ill prob get that
You can mix it to be the same or stronger it weaker, your choice, thays what makes concentrates so great is that you can dilute for different purposes if you wanted to. Thats why everyone is so upset over d114 going away
It's the same stuff. Just know that there's so much carnauba wax in it that you will need to dry it thoroughly or you will have spots on glass. It's what I use, and it's very good stuff.
OP...Put your mind at ease:
Manufacturers have Chemists that have
not only formulated these concentrated
products ("stock solutions"), but have
taken out most of the dilution guesswork
by also including the calculated dilution
ratios for the end users' convenience.
Note:
The formula for determining the amount
of a "stock solution" (at a known strength)
that's needed to make a diluted solution
(at the desired amount and strength) is:
Q1 X C1 = Q2 X C2
Where:
Q = quantity
C = concentrate
(quantity1) X (concentration1) =
(quantity2) X (concentration2)
All that's left is to: plug in the
numbers; and, solve: by the
inverse proportion methodology.
