I hope to order my first DA and accessories either today or tomorrow, I have some last minute questions about the wax that I plan to use, which is Meguiar's nxt 2.0 tech wax (liquid)
One of the cars that I am applying this wax to is painted with single stage paint that is very heavily oxidized. I will do a very heavy application of megs #7 show car glaze, polish with Wolfgang total swirl remover 3.0, then wolfgang finishing glaze 3.0, then the nxt 2.0 tech wax on top.
The instructions for the nxt 2.0 on Autogeek's store says " Tech Wax 2.0 is meant to be used on a freshly washed car free of all paint contaminants. A detailing clay will help you accomplish that. A pre-wax cleaner will also properly prepare your paint for the application of NXT Generation Tech Wax 2.0. Use a foam pad for hand applications, and a fine, foam pad on a dual action buffer if you choose machine application."
The bottle itself just says "If surface has contamination, blemishes, or deep swirl marks, surface preparation with Meguiar's scratch x or meguiars smooth surface clay kit may be required for optimal results"
Do I need to use a pre-wax cleaner or IPA wipedown before I apply this wax or can I apply it after I buff off the finishing glaze?
Will using a pre-wax cleaner / IPA wipedown have any type of negative effect on the steps that I have done previously? I am worried that applying the #7 heavy and allowing it to "soak" into the paint will be for nothing if I use a pre-wax cleaner or IPA wipedown afterwards.
Thank you!
Thank you!
