plastic bed liner protection?
PA DETAILER
before a detail this morning, i thought i would give the bedliner some protection. it is covered by a tonneau cover, so it never gets really bad. my method was a sponge and 303 protectant. turned out great. any other products you would use for a bedliner?
Since it's a bedliner I would use something inexpensive and would entertain even using Armor-All....
Is this a sprayed in liner or a drop in one???
If sprayed in I would avoid any product that has wax, solvents, or silicone in it! If you use these types of products it will cause the UV coating to fail and it WILL become chalky!!!!
If drop in it can get anything that will make it shiny I would go with Bob and say Armor All would sufice...
drop in. had the 303 lying around so used it. i figured. anything cheap in the future.
