Tato
- Nov 27, 2013
- 2,157
Careful application of heat can minimize scratches like these
What they are describing is very tricky, and although I agree that it does slightly improve the look, it does not restore it, mainly because the texture of the piece was physically altered by the scratch. So although I do support the suggestion, I would have to warn to have realistic expectations since heating and manipulating the trim just a "bit" too much would definitely convert a small problem in a bigger one.
The mechanism in which the heat gun works is based on the fact that the damage to the plastic leaves micro/macroscopic "frayed" edges and the heat will melt those thin plastic edges into something that would not catch your eye as much. It is essentially the same process (although mechanical and not thermal) that we use to "blend" a RIDS. If you CAN'T safely a RIDS, you can at least feather it so that only a trained eye or a keen eye looking will find it.
When using the thermal method, you heat the plastic till what you perceive is the best you can do.... then you dress it (or coat it). Personally I would not run the chance of putting heat to it if a more conservative cleaning and coating (DLUX) would work![]()
check out U tube there is a good vid on how to use heat gun on plastic trim
