What "type" of plastic is it?Yo
I am doing the detail today. So I need to fix it on the spot
You just may wind up having to find something to act as a "stiff-leg" in order to exert enough pressure to polish the ragtop's plastic window...Without causing the window to separate from its fabric pocket.I'm still frustrated about the back window.
If you look in this picture you can see what kind of plastic window I was working with ...........
As you can see the plastic rear window is extremely oxidized. Every time I tried the plastic x on a polishing lad the window would cave in. Making it nearly impossible for the lad to do its job.
1z deep plastic cleaner works great.
