emmjay
Member
- Feb 2, 2015
- 848
Hello Mike and everyone who reads,
I have finally corrected a Honda Pilot, god its huge! I have also applied solution finish due to which I cannot continue tonight (its 10 pm here) as the solution finish needs to cure.
As soon as morning arrives I would like to coat the car and get it out of the way as its been 5 long days with this car...I dont know how you guys do it.
I want to use the PBL surface cleansing polish to prep the paint, but I have already taken off allll the tape to use solution finish and to make sure the tape doesnt bake in this heat. The Pilot has too much plastic trim and if the PBL Surface cleansing polish stains trim then I do not want to use it and I will use Wolfgang perfect finish paint prep instead.
I would like to stay in the PBL line as I want to use the coating, but I do not want to if it stains trim, rendering this purchase useless, as I will probably never use it if it stains trim.
+ + Its 40 degrees in the morning here (105), any tips on how to use the coating? Smaller areas, faster wipe off, anything to make my life easy?
Thank you so much!
Thank you so much!
