please help me with my menu. ignore the grammar need help with the substance of the menu.
Bierman
Menu- We use steam and modern chemicals to detail our vehicles inside and out. Our steam cleaning process only uses about a gallon of water per wash, oppose to 40+ gallons of water for the conventional method. Our steam cleaning method is 100% safe for your paint and can handle any vehicle no matter how dirty. Because of the little amount of water we use we are able to wash your vehicle just about anywhere, including indoors.
XPRESS DETAIL- (around 2 hours to complete) 80*
Exterior- steam clean exterior, clean wheels and tires, dress tires, clean windows inside and out and apply rainx , apply quick wax
Interior: vacuum interior, vents sanitized, nooks and crannies spot cleaned, wipe down and dress interior
deluxe detail- (around 5 hours to complete) 225*
Exterior-Bug splatter/road grime/tree sap removed, steam clean the exterior , clean wheels/wheel barrels( back side of wheels)/ wheel wells, dress wheels, protective coating applied to wheels, clay bar paint (makes paint smooth by removing contaminates stuck on the paint, also allows wax to bond with the paint), restore and protect exterior trim (black plastic parts), top of the line wax applied (protects paint for 3-4 months), Windows cleaned inside and out and apply rainx.
Interior- thorough vacuum, upholstery shampooed and extracted, light stain removal, leather deep cleaned and conditioned, all nooks and crannies cleaned, Door jams cleaned, vents sanitized, all interior plastics cleaned and dressed, headliner spot cleaned,
Signature detail-(around 8 hours to complete) 350*
Exterior-bug splatter/road grime/tree sap removal, steam clean exterior, engine area detailed, wheels/wheel barrels/ wheel wells cleaned and dressed, protective coating applied to wheels, clay bar paint (makes paint smooth by removing contaminates stuck on the paint, also allows wax to bond with the paint), 1 step paint correction (polishes paint to remove spider webbing, swirls and other moderate paint defects), exterior trim restored and protected (black plastic parts), nooks and crannies thoroughly cleaned and dressed, door jams cleaned and waxed, top of the line wax applied (provides 3-4 months of protection), cleaning of windows inside and out apply rainx,
Interior-thorough vacuum, upholstery shampooed/extracted and protected with professional grade fabric protector, leather deep cleaned and conditioned, nooks and crannies spotlessly cleaned, vents sanitized, headliner cleaned, door jams spotless cleaned, all hard interior plastics cleaned and protectant applied, in depth stain removal, headliner cleaned.
maintenance detail- Find words to go here>>>>>> I need HELP!!!! :((((( :O
Additional services- can be added to any package detail
scratch removal- call for a quote
headlight restoration- 100
paint transfer removal- call for a quote
heavy stain removal-call for a quote
odor removal- call for quote
vomit clean up-150*sticker and badge removal- call for a quote
Do you have a clean interior but neglected exterior or vise versa? You can mix our xpress interior and our signature exterior to suit the needs of your vehicle.
*all prices and time of completion vary according to the size of the vehicle and how well the vehicle is maintained.
