My clients 05 BMW 3series has some type of glue or adhesive on the driver rocker panel. I tried using megs body solvent and apc+ and neither did a thing! I let it agitate for at least 10 minutes too.
So if you have any ideas they would be greatly appreciated!
rops:
Hi SouthernStyles,
Sorry for the late reply, was working on a behind the scenes project this morning.
Good pictures! That helps.
Is it rubbery? Or solid like dried epoxy?
Either way it will be tough to remove an not harm the paint. Try the products recommended already as the goal is to find something that will dissolve the glue without harming the paint.
There's a new company that offers a number of different paint and adhesive removers and some of our forum members have had luck for their application.
Here's the link to their website,
Motsenbocker's
I would call them and try to find someone that works on the technical side, even steer them towards your pictures in this thread and see if they have any suggestions.
Here's their contact page, where you could copy and paste the link to this thread,
Contact Motsenbocker's (They're in San Diego = Pacific Time)
and their Customer Service Phone numbers
Direct: 858.581.0222 ext.110
Toll Free: 800.346.1633 ext. 110
I've found some of their products available at Lowe's which means they're likely available at other hardware stores also.
Besides that there's the usual,
Goo Gone
Goof Off
Turpentine
Mineral Spirits
Lacquer Thinner
Plastic Razor Blades
Popsicle Sticks
Your fingernail
40 Grit sand paper to knock the top portions off to start with
And whatever you can find or thing of, in a perfect world you could find out exactly what the substance is, locate the manufacture and ask them for a way to dissolve it safely.
Best of luck and please update this thread with any updates...
