Please tell me these can be fixed!
rotzilla
While picking the truck up from the spray on bed liner place, I noticed adhesive on the side of the truck, I requested that it be corrected, youngster went out with a cloth and bottle of alcohol, didn't think much of it until we went out for final inspection and found these (:(pics)
After some discussion I took the truck home and attempted to correct the problem, after using adhesive remover, and clay bar I realized they were actually scratches in the clear coat, not sure if he rubbed all the way through or not.
Shop is arranging for a correction later this week. Does it look like these can be fixed?
That looks fixable, but from what I see your going to have to, hopefully just clay
If not with that little spot you can just work by hand, light swirl remover, medium, then compound
I use a MF towel in these cases because your CC still looks healthy.
(I could be wrong however)
