po85rd question
s500
is po85rd a final POLISH i could put on after m205 and will it give a nice reflection on the car or is there a polish i could use to get better results. if i use menzerna power lock sealant after, is it necessary to use collinite 845 on top. would it give it more wetness or shine or are there any products you would recommend.thanks
I use 85rd many times after using 205 and the car looks great you can work 85RD so long the more you work the better it looks just don't dry polish . After the 85rd I topped it with BlackFire wet diamond sealant wow it was slick and wet . When I get some time I will post it
i very recently tried the 85 rd and it's truly unbelievable.
I just polished my brother's gloss black pillars and trim around the side windows on his car and it took off all the swirls and defects. I used it on a low speed with a finishing pad between 1000-600 rpm. I love this product. I used it on the rest of the car too because it's so nice.
any recommendations on a good sealant and wax for best shine
i typically follow po 85rd with two coats of blackfire wet diamond sealant.
Gah! I am not sure what to get, either BL or po85rd! I know they are different products, but they can be used for similar purposes! I only have enough money right now for one. :(
if you can only get one bl serves more purposes
BL=Black Light:confused:
You don't need to final polish, but you do need to protect your paint from the elements. BL would not be my choice for protection as it is not a very durable glaze by itself.
