When looking into the subject of paint thickness a little I came upon this post:
TECH TIP: How polishing impacts clear coat thickness | GMC Truck Forum
That's a well written post on the topic by Dylan Von Kleist over at RUPES. It's always rewarding reading things like this,
[quote Dylan VK]
HOW MUCH CLEAR COAT DOES POLISHING REMOVE?
Just as the depth of scratch or swirl mark you're working to remove can vary so will the amount of clear coat you'll need to 'remove' in order to correct it. Most imperfections will be removed somewhere in the 1µ to 4µ range. Average swirls and light imperfections will fall in the 1-2µ range and deeper
RIDS and scratches will fall in the 3-4µ range in terms of how much surface will need to be removed.
[/quote]
Here's where the term RIDS came from.
RIDS - The Definition of RIDS and the story behind the term...
And when doing a search via Skynet, I found this,
RIDS - The Free Dictionary
Acronym Definition
RIDS Rules in Database Systems (conference)
RIDS Random Isolated Deep Scratch (automobile cosmetic maintenance)
RIDS Records Inventory and Disposition Schedule
RIDS Reaction-Induced Difference Spectroscopy
RIDS Record Inventory Destruction Schedule
RIDS Review Item Disposition System
RIDS Reaction-Induced Difference Spectra
Pretty cool. An term and acronym I came up with is recognized by a dictionary and used all over the car detailing world by my peers.
My takeaway: most defects are no deeper than 4 microns, and a typical clear coat is about 50.
Yeah, President Gerald Ford tried to get the U.S.A. to switch over to the Metric System back in 1975 and it never took. While I'm all for using metric where needed, what I like to do is talk to people and type to people in terms they can EASILY UNDERSTAND and that's why when I wrote the below article and also included it in my how-to book, I used MILS not MICRONS and I used something that almost anyone in the world knows about and likely has access to - a simple Post-it Note.
Clearcoats are thin by Mike Phillips
The
factory clearcoat on a new or modern car measures approximately
2 mils thin.
The average Post-it Note is around 3 mils thin.
The next time you have a post-it note in front of you, feel a single post-it note between your fingers. Like this...
You can easily feel how thin this piece of paper is correct?
And now you can EASILY WRAP YOUR BRAIN AROUND HOW THIN the clear layer of paint on your car is.
A Post-it Note is THIN. And the clear layer of paint on your car is THINNER. Pretty easy to wrap your brain around mils using this example. I couldn't do this with microns. I know some guys like to use microns but I like to keep it a LOT more simple.
Back to you and your paint
There's a lot of guys on YouTube and all over the Net telling everyone how thick the clear layer of paint is on modern cars and I'm the only one I know of that has documented this information and also given due credit where credit is due.
In
post #14 of this article I wrote in 2010,
Beginning Clearcoat Failure
I share the information I obtained from
Dr. David Ghodoussi - NOTE the text I turned RED
From post #14
There's only three people that I've ever spoken to that are knowledgeable about clear coat paint technology and what causes them to fail, these would be,
- Dr. David Ghodoussi
- Claude Sevigny
- Prefers to remain anonymous
The primary causes of clear coat failure are,
- Exposure to UV light, the closer to the sun the more damaging the effects, this means geographical locations nearest the equator.
- Too thin of a top coat - Top Coat = the clear layer of paint.
- Neglect and extreme neglect of the top coat.
- Using harsh chemicals and incorrectly using abrasive products.
- Swirled and scratched paint - Swirls and scratches in the paint open the paint up allowing corrosive elements to more easily deteriorate the paint faster.
You can only control a few of the above factors so do the best you can with what you do have control over.
When it comes to item #2, I spoke with Dr. David Ghodoussi about this and he shared some VERY INTERESTING information.
First, some of you probably don't know this but Dr. G as a part of his work background has worked for a number of Paint Manufacturers. These would be the paint companies that provide paint for the OEM and Refinishing industries.
He told me when he was working on creating clearcoat paint technology, this would be back in either the late 1970s or into the 1980s, they of course did TESTING. They found that
less than 2 mils of clear paint over the basecoat would lead to pre-mature paint failure.
Simply put, with less than 2 mils of clear, there wouldn't be enough paint overall to hold-up over time. It's simply not enough "substance" to withstand exposure to sun rays and the elements.
They found that at least 2 mils were needed to provide enough substance to create the final matrix of paint, that is the e-coat, primer, basecoat and clearcoat - that this amount of film build could and would hold up to the elements.
THIS IS WHY CARS GET AT LEAST 2 mils OF CLEARCOAT AT THE FACTORY. NO MORE. NO LESS
Now I'm not an expert at car manufacturing, but I know that to spray MORE PAINT on a GRAND SCALE (that's what car manufacturing plants do, build cars on a huge scale), that spraying more paint means more gallons or tons of paint being sprayed and this equates to more money and also more time for the paint application process.
So my educated guess is, car manufactures could spray more paint but they don't, the spray "enough" paint for the paint to hold up for normal wear-n-tear and that's it.
Paint the car and send it on down the line for further assembly.
This is why it's safe to say, when it comes to the factory finish on a modern car, the clear layer of paint is approximately 2 mils. It might be more... hopefully not less. But when we the detailing community work on our own cars or someone else's car, we should be knowledgeable about the thin aspect of factory paint and this is the reason for the sage advice,
Use the least aggressive product to get the job done
That's the backstory to the word RIDS and also why the factory clearcoat is only 2 mils thin and the reason I use mils instead of microns to help people figure this stuff out.
I use a two-bucket wash method with grit guards, good microfibers, and a pre-rinse with foam cannon. So I figure that 46 or so microns left over will last a long time. It's infuriating that I put roughly 2 hours into my ROUTINE washing/detailing process from setting up, to washing, drying, etc., cleaning up, all with good methods to prevent defects, and something like this happens.
I feel your pain -Bill Clinton
I feel your paint -Mike Phiilps
I feel your pain man. Here's the good news...
Meguiar's M105 is very safe. You're not going to have any problems.
So give it a go and let us know how it turns out.
