Polish Angel Glasscoat Cosmic (Quick Take)
So received my Polish Angel group buy items from Autopia the other day and in true fashion I couldn`t wait. One reason being is I with most products, especially coatings I like to try them on my personal car first just to be sure they don`t act funny during the application process.
That being said I wanted to share a few thoughts so far on the PA Glasscoat Cosmic.
So the test subject was non other than my GTO. This car has had a bunch of different coatings on it. All good but some I like better than others. The most recent has been CSL (Crystal Serum Light) which has been my go to coating for the past couple months. Only reason I am removing it off the gto is for this test.
Here are the products received after unboxing. I like the little box that the Cosmic comes in. Kinda like opening up a special little gift lol! Inside I was greeted with the Glasscoat Cosmic, applicator pad and a pair of nitrile gloves. I also received the primer polish and Glissante shampoo and Cosmic Spritz coating topper.
I wasn`t able to capture any pictures of the prep and install process as my phone went dead shortly after taking the above pictures.
For preparation I wiped off the car with some WG Uber Rinseless wash. After I decided to polish the surface with Polish Angel Master polish just to be sure I removed the previous coating as much as possible. I used a white LC pro thin pad and my 3401.
Now after this was done I followed the directions and used the Polish Angel Invincible Primer polish. Turns out according to the label this stuff can cut depending upon the pad choice. I didn`t get to test the cutting ability as I used a black LC pro thin pad on the 3401 on speed 3-4 and just lightly went over the surface and removing as I went along. It wipes off easily with no dusting or funny business. It does seem to add a gloss. I am thinking this is similar to Carpro Essence.
After going over the car it was time to apply Glasscoat Cosmic. I opened up the bottle and put a few dabbs to the nice foam applicator pad began applying it in straight back and forth motions. Just like hand waxing a car. It applies very easily and little goes a long way! I barely made a dent in the bottle. I only did one coat but it says that after 2 hrs from the first coat you can add a second layer.
After I applied it to the whole car I had to wait 30min before removing. Once time came the Glasscoat removal was effortless. Took maybe 10min to wipe the whole car down. Then an hour after that I hit it with Cosmic Spritz and let it sit.
One thing I noticed is that the following day the applicator wasn`t hard like some of the quartz/Ceramic coatings out there.
If this is truly a coating then its pretty neat how it applies. No worries about high spots and streaks. We will see how it performs. The gloss is nice and it has a glassy just coated feel too.
Some after shots.
Looks great Justin.Myself and (281) applied cosmic to my Subie about a year and a half ago and it still is holding up well. I have also been maintaining it by washing with HydroFoam. PA does make some top shelf products.
Thanks for the review. I ordered some earlier today and can't wait to try it out.
Great write up Justin.
Just a note, I did my hood the same way you did with the PA Polish and Primer and Cosmic then did the rest of the vehicle with just the Primer and Invincible Combo. Primer definitely does have some minor correcting ability and on a well maintained car will polish it up nicely. I think if I remember correctly I used a white B & S pad on my Duetto with the Invincible Primer. Also, I didn't have a coating on it, just a nuba.
It's great stuff, so easy to use. I like to apply the Cosmic with my Rupes Mini on a blue 4" LC or B & S pad, a PC with 3.5" bp works great too.
Both of your rides look outstanding!
Thanks for your feedback! I was thinking about applying it with my gg3 and a black 3in foam finishing pad like I would a sealant or wax. Maybe next time.
I think I am going to try the Invincible Primer with my 3401 and a orange or White LC pro thin pad on a 900 mile black c7 Corvette on Saturday. Then follow up with Cosmic Spritz. The customer doesn't want a coating. The car only has some very minor love marks on it from what I saw underneath my lighting. Should look nice when finished.
Excellent review! Your GTO wears Cosmic well, I hope it lasts a long time for you. I keep saying I need to pick some of this up for my AMGs as a treat for them, but I keep forgetting to. How does the paint feel afterwards, as far as slickness goes? I keep going back to BFWD in chasing that aspect, but I know a coating would probably better suit them.
Thank you very much!
The paint has a very slick glassy feel. It feels just like a perfectly clean smooth windshield.
The application process alone makes this product a front-runner for me when my current stock of stuff runs out.
I really like the idea of an LSP which will last a year, regardless of what you call it. Even if it only holds up a year, I'll be happy. I'll eagerly follow these threads to see how the product holds up.
Can you use the primer by hand on the smaller parts of your car to get the primer capabilities onto your paint? And can this coating be used on glass and wheels as well?
These products are absolutely next on my list. Great stuff!
Yes PA seems to have quality stuff. Just wish it was a little bit more budget friendly!
Mine too. I will be applying the primer and coating in fall on both my personal cars.
Sent from my SM-G935V using Tapatalk
Awesome! You will like it.
That's kinda how I feel about it too. Only reason I have a coating on this car is for test purposes. It stays in a garage and is well maintained.
Yeah you should be able to use it by hand in smaller areas. I don't believe that it's recommended for glass. As for wheels if they are clear coated then I don't see why not.
Not for use on glass, plastics or wheels. PA makes separate coating products for those. In essence Cosmic really is a wax with coating properties for hardness (silica) and shine (titania). I don't read German but you can see the lab results on their site for hardness.
Thanks for your clarification! So it's more of a hybrid. Makes sense. Kinda like PBL Synergy.
Finally received my PA products and used the directions to detail a pearl white 2016 CR-V and a Blue Pearl 2016 Pilot this weekend.
Assessment on the CR-V: As mentioned by all who have used the products, application and removal could not be simpler. Used the BOSS G15 to apply the Invincible Primer to large areas and a foam applicator pad for the tight areas. Applied 2 coats of the Cosmic Angel with specified 45 minute rest between coats. Followed that up with Cosmic Spritz as directed. I'll try to get pictures later but results were very similar to the Nissan Rogue above. In direct sun, my wife commented that she had to shade her eyes against the reflection. VERY impressive results on a white car.
Assessment on the Pilot: Only one real difference here. PA has an option on their site to order the Cosmic Angel in a color specific formulation. They don't provide any information about the benefits, but I figured what the heck. Instead of a cloudy white color, the Cosmic Angel was blue. The wipeoff produced blue coloration on the microfiber.
All in all, my search for the products that will be used on my daily drivers is over. I plan to simply wash (probably Griot's Brilliant Wash) and use Cosmic Spritz as a "drying aid / coating enhancer".
As noted by others above, the amount of product used if you follow PA directions is very small. I would compare usage of the Cosmic Angel to the amount of Collinite 845 needed to coat the same car. A little goes a long way and the cost per application becomes very reasonable. I would expect the Cosmic Angel to last the life of both cars (which I plan to be a long time).
Are you sure it's a wax with coating properties? If so, then what's the difference with something such as synergy?
Justin, looks great and I used PA Viking with great ease of use and results
