Polish Angel Viking Coat 10 Months old A++
I'm very impressed to say the least with all the salt and brine that they put on the roads in Southern Ontario Canada. I was figured it was a myth I now believe in Angels! There is a bit of fallout on the roof but the is expected if I have to clay and re apply in the roof. Not a huge deal still reacts as it should. Next order coming up.
Sent from my SM-G900W8 using Autogeekonline mobile app
I'm very impressed to say the least with all the salt and brine that they put on the roads in Southern Ontario Canada! There is a bit of fallout on the roof but the is expected if I have to clay and re apply in the roof. Not a huge deal still reacts as it should. Next order coming up.
What is your maintenance routine to keep it going? Nothing but a bucket wash?
Winter time was just a quick rinse with the powerwasher to get all of the salt/ brine off. Nice warmer days would foam it with Polish Angel soap and do a 2 bucket wash. Then use a car dedicated leaf blower to dry it off. The shine is awesome with this stuff. I read alot of articles between Autogeek and Autopia and the reviews and pictures don't do justice until you actually see it first hand. Prep is key but once that's done it's pretty straight forward. I just hoped onto the waterless wash train to see how that works out.
Roughly hit the one year mark with the the Polish Angel Viking Coat. Paint is still acting like day one. Broke down though and re did the hood roof and trunk as I could feel a bit of fall out. So I just recoated those parts. Been on the water less train using Car pro Echo 2 WW with no issues affecting the water shedding. Very impressed with how the car cleans up. I wasn't a believer on the WW stuff but truly am now.
Sent from my SM-G930W8 using Autogeekonline mobile app
Just a quick suggestion for you, instead of claying polishing and redoing a panel, try just using fall out remover like Iron X. Honestly, with how good coatings are nowadays, after a good Iron X decon the paint should feel smooth again. I live in Toronto here and after the spring time, I basically just iron Xed my car for my basically one and only 2BM wash of the year and the paint was smooth again.
Sweet man, I'm going back to a coating in the fall and I really want to try out the PA stuff!
nice. you can always use the viking spritz to to boost it up. what about swirls? You havent even picked up 1 in a whole year? not even in direct sunlight?
19 Months with using Polish Angel Viking coat on my daily with 2nd Winter nearly completed. Never used any Polish Angel spray on Viking coat toppers through its life. My opinion on this product is it holds up true. My hood and roof were the only areas re done as I micromarred them awhile back. The sides were 19 months they still bead from the window areas to about 4 inches below that. Anywhere else on the front or sides has no life left. New order of PA coming up
Have you tested to do a decon wash with tar and iron remover? And test with washing with carpro reset car soap which is one of the best cleaning car soap out there and made for coatings. As in it leaves nothing behind as no glossenhancer or wax or polymers. Test to wash with reset the coming 3-4 washes and see if it revives it. Or after the decon wash apply PA Viking Spritz or PA High Gloss to extend it some months more.
Thanks for shareing your experience with the viking coat. And intresting to hear that you are at the longevity claims without any toppers.
That’s a bold statement...
Just the add to my original I have used everything from Polish Angel Glissante soap, and Car Pro Echo 2 water less wash. And the occasional Chemical Guys Honeydew soap. Nothing ever really had any negative effects that would make me stop using the different brands.
Wouldn’t the Carpro Ech2o qualify as a topper?
There's been quite a few discussions about it before but I stick by my statement. I don't really get sap on my car after winter time, summer time I do but I just remove it when I do my usual washes. Iron X and Tar X takes care of whatever actually gets stuck on there. To be honest, I don't really know what other contaminants are getting stuck on cars that a coating wouldn't protect against except for some tar/tire rubber, and iron fall out from brakes and what not. I've clayed behind the tires, and the horinzontal panels but I don't see the clay pick anything up after I've chemically decontaminated the car. The OP does use a different LSP then I do but I don't see why there would be that much of a difference.
Sure it has some sio2 in it so maybe a little it's adding. But I don't think that it has that much of an impact to the longevity. It's about the same with any waterless wash with wax in it I think. At the end of the base protection it's holding up between washes. If the wash solutions with added protection in them would be the only needed lsp if they ads a significant of protection. It's hard to say what it really ads that impact the longevity of the lsp. Just my thoughts about it. With the spritz product is another story which claims to about 6 months longevity on it's own. But it's strange with toppers and their capability to extend the longevity of lsp. If you where to apply PA Viking Coat and use Viking Spritz as a topper every 3 months. When would the Viking Coat be gone? And it's a intresting question with all of the base lsp and the use of the toppers recommend applyied in the time range of their longevity on their own.
