I have a question about something I have noticed when using my PC 7424. If I work the polish at lower speeds 1 to 4, I can see the product being spread on the surface. But after a few passes of working at lower speeds and if I go to a little past 5 or all to speed 6, the pad will remove the polish that has already been worked on the surface. Yet if I back to to lower speeds, then a thin layer or polish is visible on the surface again.
Does this soud like something I am doing wrong, or is this perfectly normal at higher speeds with the PC? I have never experience any prblems with dry polishing, so I know it's not from not using enough product. Whenever using dry unused pads without any product, I will usually one quick spritz with something like the Pinnacle pad prime or ONR mid at QD strength to somewhat moisten the pad from dry polishing. Could this be related to what I am seeing? I am using the LC CCS pads if that makes any kind of difference
