Polish/Sealant and RAIN
Locutus
So i am working on a friends car, and we were able to wash and clay the car yesterday, but had to stop. Now today it is raining. My question is if I have a garage, can I dry his car off and still polish and apply DP Poly coat? Or will the rain/humidity prevent it?
The humidity might make the polish a little harder to work with but as long as you are in a dry enviroment go ahead and polish. The only thing is you do not want to get the car wet right after applying the sealant. The sealant needs time to bond to the surface and the rain will effect it from bonding unless of course if you let your friends car stay in the garage till the rain stops.
Well the roads will be wet, so about how long should I wait before getting wet.
You want to at least give it 12 hours. If it is as hot as it is here the roads should dry pretty quickly and you will be good to go. Also don't forget about the dew that starts around dusk since you said it was humid where you are at.
