Polish tips
pyles1735
Just ordered some wolfgang gloss enhancing polish along with my order. Ive never used a polish so I'm looking on tips on how to apply it.
My plan is to do a wash, clay, polish, then Megs Gold Class. But anything I should know or tips?
Sent from my Desire HD using AG Online
Dependent upon your vehicle's paint, you will have to adjust your polisher speed, hand speed and hand pressure if using a machine. It may take several tries to get the perfect finish of your liking. Try taping your hood into sections big enough to test. I will usually do 4 or 6 different sections depending on the size of the hood. With each different section adjust your technique a little. At the end of your trial and error period, untape and stand back to see what section suits your needs. You will then know what technique to use. Do the whole vehicle with that technique. Then apply a THIN layer of your gold class (which is also one of my go to's). I recommend using a good quality quick detailer to wipe your paint down after wax removal. Meg's ultimate quick detailer is a good, cost effective qd. And can be found otc. Any other question's just let me know if I can be of any assistance.
I appreciate the help. But I should of said Id be doing it by hand. Do I let it haze or buff it off before it does?
The more you work it with your applicator... The more you will notice it sort of dissapear or break down. Once it starts to break down and dissipate, this is typically when I wipe that area clean. Remember to work in smaller sections. Probably 2x2 foot is a good starting point. You will just have to test tto see what process, and work time achieves your results.
