Zaino and Duragloss use to offer a preping/polymer/curing agent that was applied, not removed and then coated with their sealant. I would not however do this with any other product specifically.
Also your friend has the wrong order ... its polish, sealant, then wax. Of course suggesting removing each prior to moving to the next step.
killrwheels is right, both Duragloss and Zaino have products that you apply using a thin layer and then leave this layer on the paint and apply the sealant right on top of it.
While it's always best to follow a manufactures recommendations as they know their products best, in my mind, if you rub a smooth creamy product over the paint and don't remove it you risk potentially scratching the paint when you apply the next product because it's possible that the first product may have loosened some kind of contaminant or impurity and now it's embedded in the dry film you left on the paint.
It's probably not a HUGE risk, but that's how my mind works.
Apply and remove products one step at a time.
CTS-Veo posted some thoughts about your friends process that I also have. Buy hey, if it works for your friend and they're happy, then let them run with it. Of course you could also share the link to this forum with them and let them share their process and we'll all discuss it and see what shakes out.
The Duragloss 601 PBA is part of my Duragloss routine simply because the manufacturer recommends it.When I first read the original article, I was baffled by the suggestion to apply a polish without buffing it off and then apply wax or sealant on top of it. But perhaps, as killrwheels has pointed out, the individual was using a product like Duragloss 601 Polish Bonding Agent. One doesn't hear much about 601, but it's supposed to increase the durability of any polymer sealant that is applied on top of it. Has anyone used it before? Has anyone used it with non-DG sealants?
well, its true with amazing results.
Actually, he uses a rotary buffer to apply the polish and remove scratches, then a dual action and polishes again, then paste Carnauba wax, then a paste polymer sealant, in this order. Its all on DVD but because of the rules here, not going to give that info out. I'm trying to get the brands from him.
Sounds suspect to me... What DVD?
