Good Evening:
The next week I will be traveling to Southern California on business and will have an opportunity to see my family.
My sister asked me to wash and wax her car this year as a Christmas Gift... I agreed -this car was last washed by me December 2016. Then she threw me the curve-ball, that it is due for lease turn in in February, but they did their pre-inspection and noted that it is "very dirty" and ran it through an automatic car wash. They noted that unless she fixes it or buys it, they will be billing her up to $1400 to re-paint the driver-side fender and hood due to very apparent bad water-spots that "won't wash off," but otherwise the car is okay.
At any rate, my father bought a Grit's DA (the no thrills 8mm) with these pads:
[TABLE="class: apm-fixed-width a-spacing-mini apm-fourthcol-table, width: 969"]
[TR]
[TH="class: apm-center, align: center"]
[/TH]
[/TH]
[/TH]
[/TH]
[/TR]
[TR]
[TD="class: apm-top"][h=4]5" Vented Backing Plate[/h]Experience reduced surface tension, faster pad rotation, and quicker defect removal.
[/TD]
[TD="class: apm-top"][h=4](2) 5.5" Orange Foam Correcting Pads[/h]These pads are the proper density for use with all of our polishes. They excel at removing light to moderate defects.
[/TD]
[TD="class: apm-top"][h=4]5.5" Black Foam Finishing Pad[/h]When used with polishes and sealants, this pad removes fine swirls, scratches, and light defects on the most delicate paint finishes.
[/TD]
[TD="class: apm-top"][h=4]5.5" Red Foam Wax Pad[/h]This pad is made for the precise, even application of waxes and sealants, ensuring easy product removal and vibrant, uniform color.
[/TD]
[/TR]
[/TABLE]
My dad basically volunteered that I might be able to remedy the paint... that I worked miracles with my mothers car that has 8 year old paint that still looks new.
Do you think that pad choice will be sufficient? Is their black finishing pad a polishing pad? I ask because usually I put waxes on with the black finishing pads in both the Lake Country and Meguiar's offerings. How much cut does the orange one have? I have a TON of the inexpensive 5.5" Lake Country Open-Celled pads... Should I bring any? I definitely want one that can polish and one that can do some cutting.
Will a LC pad run on the GG backing plate or is the hook and loop different?
Additionally, I asked my father what he has to polish with, and he said the only polish he bought was the Meguiar's 205 because that's what I told him to get started with...
Okay, so for air travel, is it any trouble to check a compound or two in your checked luggage?
What I have in my arsenal that has some correction ability:
SwirlX
ScratchX
ColorX
Ultimate Compound
Ultimate Polish
205
105
Menzurna SF4500 (now 3800)
Menzurna 2500
Menzurna Heavy Cut 400 (Used to be FG 400)
If I can bring them checked in luggage, what would you bring??? I want to keep what I bring to a minimum.
[TR]
[/TH]
[/TH]
[/TH]
[/TH]
[/TR]
[TR]
[/TD]
[/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
SwirlX
ScratchX
ColorX
Ultimate Compound
Ultimate Polish
205
105
Menzurna 2500
