Couple of questions:
1. I have seen pictures of Mike thoroughly masking a vehicle prior to compounding. If I a polishing a new vehicle and am only using a fine polish (Menzerna SF3500). Do I need to be worried about masking everything? My thought was I would stay away from any edges until the polish was worked in a pass or two then I should have little risk of leaving residue where I don’t want it. I I plan on masking areas I can easily do such as the windshield, but to mask every rubber seal around the windows, and every plastic trim piece seems like it may be unnecessary if just using a fine polish.
2. Related to the above. If I waited until the polish was worked in a pass or two (and broken down a bit as it’s a DAT) can I safely go over breaks in a panel (such as you would get between doors or over the gas cap door, etc).
I have minimal experience with polishing (have only done sons car) so I thought I would gather the thoughts of the more experienced.
Thanks!
Thanks!
