polishing chrome and stainless window trims bumper etc
Hey guys, just wanted to ask if you had any tips for buffing and polishing chrome and stainless window, door, bumper trim and any other.
I have a couple older vehicles (70-80's) I will be detailing and wanted to know how you guys do these type of tight spots.
I plan to clay then use chrome or metal polish depending on the material followed by a sealer.
One issue I am concerned with is not spreading product from the trim to the paint. I am guessing taping off will be my friend in this scenario.
Thank you.
Tape will be your new best friend. There's only so much you can do with a DA/metal finishing.
Small pads, bp's, rotary extension, and a rotary will help tremendously.
Check Mike's tool/accessory/product choice
When it comes to stainless, the best you can expect is to brighten and color the metal without proper sfpm's for correction.
http://www.autogeekonline.net/forum...28-1947-buick-land-yacht-grill-polishing.html
I also like using 6.25" OMF finishing pads/Mothers al. polish/9227 on bumpers. Both for removal and application.
On trim and tight spots, I use felt polishing attachments on a dremmel with a metal polish.
When i was younger i was a nut when it came to polishing metal. I have used so many products its not even funny. One product that stood out way above all others was wenols. Just giving my 2 cents on a good metal polish that may help you out.
Well, I'm not a metal polishing expert, but - I do know how to polish exhaust tips. I tried the standard stuff: Meg's Metal Polish, Nevr Dull, etc... Nothing worked to my expectations... until... I tried P21S Multi Surface Finish Restorer:
Before:
After:
Then you can maintain it with the P21S Polishing Soap. Nothing has worked for me like these 2 products.
Before:
After:
Wow, I've never gotten my tips that clean using P21S Multi Surface Finish Restorer - how did you apply it?
Small Wheel Woolie in a drill used to polish. I think I actually made this technique up. It gives amazing results for inside exhaust tips. But, the P21S FR worked better than "metal polish".
Very cleaver. I like it. I've been on the fence about picking up a set of wheel woolies - this seals it.
