Background:
Hi everyone! This is my first time attempting to correct / polish a vehicle.
The vehicle is a 2018 Acura RDX and the paint is black.
I did a test on the driver side doors middle section and it is not finishing out how I expected.
Here is the paint condition BEFORE:
Tools:
* Griots G9 with stock 6 inch plate
* Griots black finishing pad (not boss)
* Griots Perfecting cream
Process:
The car was first washed, iron x-ed, and clayed.
I started with the combo mentioned above in a test spot:
* speed 3
* 3 passes - slow speed and trying to keep as even of pressure as possible.
* IPA wipe.
The result in the garage looked great:
I roll the car outside and it looks amazing...at first:
Again...paint looking nearly perfect upon initial inspection, I'm very pleased:
Ok, so I assume this paint is pretty soft considering griots least aggressive setup nuked 99% of the defects in only a few passes on lower speed right...?
Then I start bobbing my head around to reflect sun light at various angles and see TONS of micro marring. It almost looks like wax applied too thick. Re-IPA wipe. No Change.
I pulled it back into the garage and do a couple more passes. Same result - micro marring everywhere but its only visible in specific sunlight.
Micro Marring:
More Micro Marring:
Micro Marring different light:
My question(s):
What does this look like to you all and what would you suggest to finish out this paint?
Here are some of my thoughts as a novice:
1. Could it be deeper scratches and I need to go more aggressive? I'm doubting it since they're so fine and the second round of passes did nothing.
2) Could the Acura black paint be SO SOFT that my setup is marring up the paint as a I go?
What could I try that is even less aggressive to see if it cleans this up?
3) If 2) is true - could my panel wipe technique be marring the paint? Is there a more gentle way to do this?
Can anyone suggest towels for delicate paint (assuming this is the issue)?
4) Is my technique just way worse than I think it is and uneven pressure (or something) is creating this? The large 6.5 inch pads do feel a bit tough to work with.
Looking for some wisdom on steps to troubleshoot! Thanks!
Tools:
Process:
* speed 3
* IPA wipe.
Micro Marring:
More Micro Marring:
My question(s):
