I routinely use a "polishing" foam pad to cut, over traditional stiff pads.
Some vendors listed the pad as a "light cut/heavy polishing"
Me too. Polishing compounds evolved so much, that I hardly use stiff foams. Obviously there are cases when it will be needed, but medium density foam is always my first choice for cutting.
This personal choice changed the way I buy pads, before I would buy more heavy cutting than medium cutting, since cutting always degrade the pads faster, but now I buy more medium cutting pads.
Best regards
Thanks everyone for all the input and information!
I hope soon Il have some friends cars that I can practice on.
So basically theoretically even if I go for a cutting pad and a polishing compound I should not expect any holograms since its the polish thats doing the work and not the pad? Even if lets say Im using a polish on a twisted fiber wool pad?
Those green pads consistently picked up more paint for me. And I believe it has a lot to do with the cell orientation. On both the orange and yellow cutting foams, their pores are much smaller, and the foam formula much more dense than the green b&s/hex, or pink lc ccs. This is taken to an extreme with the purple LC kompressor foam which has even larger pores, and is still not as dense as the yellow and orange foams.
What's great is that you can use either according to your style. Guys who use the 15lbs of pressure, and slow the pad down via that pressure are going to get better results from the traditional cutting pads. It's needed to force the abrasives into the paint. I personally feel that those who prefer a lighter touch, and go for maximum pad rotation benefit from the more open cells of the green b&s foam. They're more "gritty" feeling. However, of they are used with pressure, they're slowed down, and the benefits of the foam are lost as rotation is decreased.
Could just be me. I do things weird. When I first got my PC on 2010 I used it like a rotary and struck through paint on a neighbors car using the green foam, and Meguiar's Ultimate Compound. This is after a few years of no burns or strike through using a rotary. Speed, and light pressure, and look out! I learned that day to use that combo with more respect and today feel that I can achieve my cutting goals with that combination.
