Polishing Pal pads and Wolfgang Paintwork Polish Enhancer
Bode04
I am a total novice and have not yet tried to use any machine polishers. I purchased the Polishing Pal to apply waxes and sealants because I have some trouble with my hands and it does make it easier.
In a video I watched, Mr. Phillips was using the Polishing Pal with a white pad to apply Wolfgang Paintwork Polish Enhancer. Is this the white pad that was being used in the video the same white pad that was included in the Polishing Pal Combo?
2 White 3.5 Inch Polishin’ Pal Pads
The white polishing foam is excellent for applying pre-wax cleaners and finishing polishes. The foam has light cleaning ability to help polishes clean and brighten the paint more effectively.
autogeek_2268_438472069
Also, I am planning to apply a new coat of Deep Gloss Paint Sealant and would like to remove the old sealant and wax from the car first. Would using this white polishing foam pad with
Wolfgang Paintwork Polish Enhancer be sufficient to do that?
I've used that. Real good to keep your hands from cramping.
Better for spreading a uniform layer vs 4 pressure points from your fingers pushing on an applicator pad.
Not for aggressive polishing.... the pressure will pull the pad off the "pal"
